Questions about tuning using HPtuner
Hi,
I just got my HPtuner for my 99 vette and had some questions. I scaned my car and the LTFT values vary in each box, do I use the average, max or min for the readings and also the o2 readings. Also I changed the IFR table to adjust for the 28 injectors that replaced the stock 26. Can I do another scan right away or should I wait for the computer to learn the new IFR tables. Thanks and any advice is appreciated.
Originally Posted by cbota
Hi,
The general consensus on the LTFT tables is to average values in cells 6-14 and make sure they are between -3 and -8 for the average. I would shoot closer to the mean rather than the -3... try for -5, my suggestion only.
Don't worry about using the stock O2 readings for tuning, they are not a very good way to tune for WOT and are worthless at part throttle. I am assuming you have done some other mods to the car, not just changed injectors?
Originally Posted by GEN3Typhoon
No need to wait for a change on the IFR table.. there is not really a "learn" per say with that change they are pretty linear.
