Need help on SES code
Just installed MAC headers and ORY pipe about a week ago...All was going well until yesterday..the SES light came on. Looked up code on Oreilly's scan tool...Can anyone tell me what this code is: PO410
that code is for the air pump, did you hook all that stuff back up? if you did check for the two tubes that attach to the headers, one on each side, make sure your gasket is good, and that all the connections where put back on and it is all tight, if you didnt put them back on and blocked them off with plates then you will need to get the codes cut out from the computer, are you still using cats? jes
Hooked up all the tubes and all are tight......took off cats and put in 02 simulators. Scan tool said secondary air injection system...I deleted code and it is off for now.
