Does anyone do low cost tuning in the Denver/Colorado springs area?
I need to remove VATS and adjust gear ratios and don't want to pay the high price of purchasing ls1edit. The cost of these programming systems is just outragous.
Sam.
Sam.
http://www.ColoradoMuscle.com check out the f-body section there. Someone can probably direct you to someone in the area.
Good luck.
Good luck.
Originally Posted by P Mack
If you have a 2000 F-body I can hook you up.
The car is a Mazda Miata with an LS1 - so no BCM.
I made a circuit to disable vats but having problems with it. Want to just get rid of VATS for now until I figure out final speedo variation and adding better tables for the LS6 cam, valves, etc.
Sam.
