How will a bad MAF effect my tunning?
My car is having some tunning problems and my tuner says my MAF is reading low as far as the amount of air I am seeing to what it should be. I think it is reading 285 GPM and it should be 400+??? I am having alot of problems and I am trying to see how this could affect my tune. HELP!!!
Ok do you have a stock MAF??? I've heard that the Granatelli units have different MAF calibration tables which can screw with tuning... I have a ported stock MAF myself and it's causing a rich condition during part throttle operation of my vehicle (reading in more air than the cylinders are actually using) which is the reverse of your condition... Also if your MAF is damaged or dirty from oiled air filters it might screw the readings some... You know anything about your fuel trims??? if they are well tuned (might not mean they are dead on, but at least linear in relationship) then you can just scale the MAF calibration table up a bit to compensate for a "lack" of air reading... just some thoughts... wanna talk more bout it IM me - TXHorns281
Originally Posted by a98ws6
Stock MAF. I had it tuned. He cleaned the MAF cause it was dirt. Also tried ported ends and stock ends. No screen. I think the fuel trims are ok. He is a good tuner.
