Reducing VE Table for idle = leaner A/F
Old 01-11-2005, 09:41 PM
7 Second Club
Phil99vette's Avatar
Default Reducing VE Table for idle = leaner A/F
When you scale the VE tabel @ Idle 600-1000 does that lean your air fuel ratio out? My car idling @ 950 is 13.5:1.
Phil
Old 01-11-2005, 09:44 PM
Nickn20's Avatar
yep, I normally do 400 * 70% 800 * 80% and 1200 *90% when starting out also make sure your IACs are in line also. do a search for idle tuning, lots fo stuff here.
I try to get cars around 14.2-5 if this doesnt work you multiply those 3 tables by 90-95% leaner to go leaner. or whatever your wideband is telling you to do.
Old 01-11-2005, 10:09 PM
HumpinSS's Avatar
Are you in open loop or closed loop
