Can HP Tuners edit a PCM that was tuned with LS1edit and then locked?
I was wondering if a PCM tuned with LS1Edit and then locked can be worked on by HP Tuners? This is in regards to a 2002 C5. If it can't be worked around, would I have to get the PCM reflashed with the stock program and then start over from scratch?
Also, I have HP tuners for a 99 F-body. Can I scan and log data using it on that 02 C5? I know I can't edit the PCM with it but can I use the scanner to see how the car runs?
Thanks,
George
Thanks,
George
LS1TECH Sponsor
Thanks,
George
Thanks,
George
