Is There Any Way To Make My '02 Temp Gauge Work?
Old 02-04-2005, 07:04 PM
~JOSHUA's Avatar
Question Is There Any Way To Make My '02 Temp Gauge Work?
My friend's '98 Z28 has a gauge that will show you the actual temp. What would it take to replace the dummy gauge put in all '99+ year model cars? There must be an easy way!
Old 02-04-2005, 08:18 PM
horist's Avatar
buy an autometer water temp gauge and install a new sensor... about the easiest solution
Old 03-27-2005, 11:05 PM
TJ
TJ's Avatar
i have an ls1 dash in my 3rd gen with a 97 LT1 cluster. my gauge actually reads correctly. i have heard that all others sit at just under 210 all the time.
i used a autometer sending unit that was sent with a temp gauge i used in the past, just wired it up to the GRN wire off the back of the cluster.
hope that helps....
