A tuning issue? Missfires while cruising with low load
Old 02-09-2005, 12:27 AM
Visceral's Avatar
Default A tuning issue? Missfires while cruising with low load
I can't figure out what the issue is. When I go WOT, it feels like the hesitation/missfire goes away. But at any RPM, even 2500 plus, cruising is shakey(wiggly) because something like a missfire is sort of lightly randomly occuring. Also occurs going downhill.
Is this a sign of somethign tuning related? The cam is a 236/236 in a 387 ci All Bore engine.
Old 02-09-2005, 12:28 AM
luv2spd's Avatar
You sure its not a slight buck or cam surge?
Old 02-09-2005, 05:44 AM
LS1Tech Sponsor
Slowhawk's Avatar
Could be a plug/wire problem.
Old 02-09-2005, 10:20 AM
Visceral's Avatar
Well, at 2500, Im not used to the cam creating surge. It feels very much like one. I just am really surprised to see it up at 2500-3000 rpm
Old 02-09-2005, 10:21 AM
Visceral's Avatar
I went through all the wires... they all seem good. But I'm going to pull the plugs just for a sanity check anyways. I'd like to see how the plugs look after 400 miles in the new engine anyways.
Old 02-09-2005, 10:28 AM
wait4me's Avatar
if standing still and reving the motor does it vibrate real bad? maybe the assembly wasnt balanced correctly?
Old 02-09-2005, 01:33 PM
Visceral's Avatar
No...no other signs of poor running at all. Does everything relatively right except this ONE thing... and its a little down on power, but thats because of the craptacular ARE heads. Only 440 rwhp or so out of a 387.
Chris
