Got a M6 224 112 bin?
Old 03-12-2005, 11:28 PM
stone4779's Avatar
Default Got a M6 224 112 bin?
I am attempting to locate a couple bins with pretty similar mods to mine...
I already downloaded the only one on the repository that is real close to my setup.
It was uploaded by William Henn, here is what it says:
"2000 M6
slp airbox lid, mass air flow sensor, smooth flow bellows, ls6 intake with egr,
titanium retainers, comp cams 918 valve springs, thunder racing: pushrods,
224 / 224 .563/.563 112 lsa cam, quicktime performance headers & off road y-pipe, borla muffler, 4.10 gears
"Professionally" tuned by Julio at cartek in open loop"
Has anyone used this bin and if so, how well did it work out for you? And where are you located?(because of Altitude, etc)
I have almost the exact same setup only my cam has .082 more lift and 2 more degrees on both sides plus I dont have an LS6 intake...all else is more or less equal.
I just want to have a couple of bins handy when I do this just in case one or the other doesnt run so great....
-BTW Any input or opinions would be highly appreciated! Which tables should I copy and paste?
Is it a good idea to use this bin as a starting point? Our mods are almost exactly the same...right down to the gears... I just need something to hold me off untill later in the summer...
THANKS!
