I need to test somebodies knowledge
Old 03-13-2005, 02:48 PM
97c5's Avatar
Default I need to test somebodies knowledge
If I connect my lm-1 output to the rear o2 sensor plug, will the computer read the voltage it is sending? Will it read more than the 0-1 volt the narrowband outputs? I want to log voltage per rpm through autotap. Thanks.
Old 03-13-2005, 02:59 PM
HumpinSS's Avatar
It would have to be a 0-1 output and you will still throw codes for heater malfunctoion
