Recommendations using LS1Edit
Old 04-03-2005, 07:48 PM
67Firebird455's Avatar
Default Recommendations using LS1Edit
I have EFILive V7 and LS1-edit, and need recommendations on tuning. Mods are in signature, if any of you have a good .ls1 file for the combination let me know. Thanks in advance...
Tony
Old 04-04-2005, 07:02 PM
No comments? You've got to be kidding me... I'm starting off by matching the fuel tables on High to low octane. I am getting a little bit of KR based on what EFILive is picking up, it saw as high as 4º, in taller gears around 2k rpm. Not sure how to make it not run so pig rich at idle with the cam... Any recommendations?
Old 04-05-2005, 02:31 PM
black02-z28's Avatar
Are you saying you've done no tuning on it and need to know where to start? Fan temps would be a good first choice, get it on a dyno with wideband and check your a/f, bump in a little timing, etc. I can send you mine to peek at if you'd like, I have done a lot of stuff on the A4 side, but not a smuch to do on your M6 car..
