Explain the Vats system to me
Originally Posted by Mustang Hat'r 2
How the heck does it work?
does it cut fuel, spark, or stop the car from cranking over?
The PCM needs to see the correct (50Hz square wave) signal from the BCM that the right resistance key is in the cylinder, otherwise no fuel injector pulses, and the starter relay is not engaged. IIRC, for each event with the wrong key, a 10 minute wait period is required before the BCM will reset.
