Wanna order HP tuners....wht exactly do I need?
I ordered a LM1 wideband also. What is that IO stuff? Do I need it? On a LM1 wideband....cant I record my run and download it to my laptop? Or do I need HP Tuners to read it? Any help is appreciated.
the EIO stuff lets you plug the output of your LM-1 into the HP Tuners cable, thus allowing you to log the LM-1 output along w/the RPM and other car parameters
You can record data on the LM-1, however, unless you bought the RPM Converter too, you can only log AFR ... and knowing what air fuel ratio your car is at isn't very useful if you don't know when it was and what RPMs it was at....
the EIO gives you 4 inputs and 2 outputs (that are controlled via anything HP Tuners can log)
