Dropping Idle problem/question..
I am starting to have a problem with idle. The car will start up and idle fine but when RPM's come down from a rev or in gear it drops and cuts off.
-Start up idles @ 975
- Rev to 2000
- Idle falls
- Follower Log shows 3.0 and counts down
- Idle drops slowly as well as the follower depreciates
- Once the follower hits 0 the car is around 975 and RPM's drop and the car won't recover.
Any hints???
Phil
- Rev to 2000
- Idle falls
Any hints???
Phil
Log you ltits and stits. There is a spreadsheet around here that will build you a new raf table basedon the values. what are you IAC counts at
Here is the link to the spreadssheet
http://home.insightbb.com/~black02ss/Calibration.xls
