wideband set up to efi live
looking for a how to to get my dynojet commander to log with my efilive scanner. Is this possible? Any one know the procedure? Thanks in advanced.
Restricted User
Does your dynojet output an analog voltage signal?
Is it in the range 0 to 4.8V?
If so then hook up the wires from your wide band O2 controller as follows:
Ground to pin D
AFR to Pin C or E
If you connect to pin C, then the data will be logged on the {EXT.AD2} PID.
If you connect to pin E, then the data will be logged on the {EXT.AD1} PID.
Also check out these posts that explain how to create a calculated PID that converts the voltage to an AFR value:
for linear voltage output
for non-linear voltage output
Regards
Paul Blackmore
Ground to pin D
AFR to Pin C or E
Regards
Paul Blackmore
Is there any way to do this with Version 5? I don't have those connectors on my cable. I tried hooking the 5v reference to my A/C pressure input on the computer but It's not working out.
Thanks
Frank
Thanks
Frank
Ground to pin D
AFR to Pin C or E
Regards
Paul Blackmore
Ground to pin D
AFR to Pin C or E
Regards
Paul Blackmore
Restricted User
Thanks
Frank
Thanks
Frank
I have heard of mixed results when using the A/C pressure input. Some people claim to have it working others claim it does not work. To be confident in your logged wide band O2 data, I recommend using an interface with A/D inputs.
Regards
Paul
LS1 Tech Veteran
Frank,
I started out with EFILive Version 5 at the and then Version 6 and of course both software versions were excellent. Then, I have been fortunate to be a beta tester on Version 7 with FlashScan. I can honestly tell you or anyone else that the upgrade to Version 7 and FlashScan are well worth the money. The software and the hardware integration, ease of use and versatility are a huge step beyond Versions 5 and 6 put together.
All my best,
Steve
All my best,
Steve
