I made a convert PCM :)
I took my 2000 car and flashed it with a 2001 OS...cut and pasted every possible table so it would have all the right stuff for a 2000....
started right up...tried to idle funny at first ...tried to die anytime it had to refind idle after a little bit of gas...turned the car off...turned it back on...and it runs perfect
I guess it was just the learn procedure the car has to go thru or something...
changed so I could get rid of table 2 on VE as well as several other tables that I wanted to have
I have done this about six months ago when we first got full reflash capabilities with Tuners. It has made SD tuning less of a headache i can tell you that. Mine was an 00 that was flashed to an 01. The only thing that irks the bejessus outta me is the fact I cant use my orginal vin
