Idle issues
Old 06-07-2005, 10:06 PM
Spenser309's Avatar
Default Idle issues
My car is shaking like a back massager at idle. Its kinda strange because it purrs like a kitten once you get at about 1000rpm. these are the specs on the motor.
intake, and exhaust general stuff.
no hole in the throttle body.
TR224/224 114LSA
forged bottom end that has 10.6 to 1 compression
TR55's at a .60" gap with MSD wires
all emmison stuff is gone.
Anyone got an idea of what the problem might be?
Old 06-07-2005, 10:54 PM
Spenser309's Avatar
can anyone think of a single problem? Is the gap on the plugs too high? is the emmision stuff causing this? Or is it the motormounts?
Old 06-07-2005, 11:10 PM
shouldaboughttheZ's Avatar
mine I found out is the motor mounts. But I have no codes. Mine only acts like a bad idle.
Old 06-08-2005, 12:06 AM
Gloveperson's Avatar
You deleted all the codes for the emmision stuff right? That might have something to do with it.
I would check the plugs, wires, fuel filter, oil filter, and your gasoline.
When the car was tuned, did you get each cylinder checked for everything?
Old 06-08-2005, 06:19 PM
Ragtop 99's Avatar
what tuning was done?
The plug gap seems a bit big given you have raised the compression.
You might turn the idle set screw a 1/2 turn to open the blade a bit more if your IAC count is high.
