Mounting PCM? Does it need grounding?
Old 06-18-2005, 05:18 PM
GTS346's Avatar
Default Mounting PCM? Does it need grounding?
I have mounted my PCM inside my glovebox, but was going thru a thread and someone mentioned the PCM needs to be grounded? I know there are plenty of ground wires on the harness but does the PCM housing need to be grounded to part of the body?
The factory ones have a plastic insulating case around them but I havent seen 1 up close for ages to remember if its grounded directly or off a wire.
Old 06-18-2005, 07:41 PM
Scooter70's Avatar
No it doesn't need a case ground.
Here's how I mounted mine on the dash in the engine bay using the plastic case that I got with the PCM.
Old 06-19-2005, 02:50 AM
GTS346's Avatar
Thanks champ, mine is hidden in the glovebox but its only a carboard liner, got worried for a minute.
Quick Reply: Mounting PCM? Does it need grounding?
