iac position vs. effective area
Old 06-26-2005, 11:39 PM
bmfcamaro's Avatar
Default iac position vs. effective area
how do we adjust the iac position vs. effective area for a 90mm throttle body with hptuners?
Old 06-27-2005, 09:46 AM
WS6FirebirdTA00's Avatar
log the dynamic airflow, iac position and the desired idle airflow.
put the airflow on one plot on hp tuners and iac in the other on the graph. if the desired is higher than the dynamic then add numbers to the table for the area of the iac count, and subtract where dynamic is higher, if you log and email me the log i can send you new numbers to put in, just give me your tune file and scan, do this from a cold cold start, coolant temps ~80*f
Quick Reply: iac position vs. effective area
