Tripped a code
Tripped a code
So my check engine light came on and I put the scan tool on it. It read as follows: P1416 MOD$10 Manfacurer Contrl. Auxiliary emission Controls. Is that the AIR system? If so whats up with it. I just cleared the code out hoping that it wouldn't come back.
P1416 is Secondary Air Injection (AIR) System Bank 2 (Passenger side). Replacing the air check valve should take care of it, about $15 at a parts store. www.ls1tech.com/forums/showthread.php?t=298647
By the code number, if it was P1415 it would be Bank 1, driver's side. You can get a short explanation of codes at www.obdii.com
