when entering numbers for iac park airflow, how do you find the right values?
ok so i start my car and let it get hot (assuming all this and that i am right, this is what i have decided to go by and want your thoughts) then i see the iac temp, well it is 30*c right now and its about the highest my car sees, maybe 40 now an then or when its heat soaked. do i see what the dynamic airflow is at the warm up spot and enter that in the table? i assume this has to be hot because thats when conditions steady out?
i really am not understanding how to modify this table correctly and hope some of you can help
Not sure if this is what you are looking for:
https://ls1tech.com/forums/showthrea...dle+transition
If that gets you on the right path, then take a look at the IAC effective area thread too.
I had to do a combination of the two to make all this work.
