6 speed having issues with idle and A/C
Old 07-17-2005, 04:52 PM
7 Second Club
Phil99vette's Avatar
Default 6 speed having issues with idle and A/C
Here's the scoop. I have a 98 6 speed car cam + bolt ons and having problems getting the car to idle when the A/C kicks in.
Mods:
G5x3
TPIS headers
usual bolt ons
When you start the car up it idles fine but when you turn on the A/C, the RPM's drop down very low and either cuts off or bounces around for a second and idles rough. Any ideas?
Phil
Old 07-17-2005, 06:44 PM
P Mack's Avatar
Have you already tuned your idle airflow tables? Does your ac airflow adder pid match the actual airflow increase when you turn your ac on?
Old 07-18-2005, 10:52 PM
juiced_z28's Avatar
We have a good tune on mine with a G5X2 cam and with the A/C on mine idles up to 2000 to 3000 rpms. Sounds like we have opposite problems.
Old 07-19-2005, 07:03 AM
WS6FirebirdTA00's Avatar
should just have to adjust the idle air for the ac, but i assume you have done this already?
Old 07-19-2005, 08:28 AM
HumpinSS's Avatar
Dont move it too much because if you do and you go past the sweet spot you will see the same results. move .1 at a time
Old 07-20-2005, 12:52 AM
luv2spd's Avatar
I also have the same problem as juiced_z28 cuz my idle hangs when coming to a stop w/ the ac on. Without AC everything is perfect. So its the idle air or the ac torque table that needs adjustment?
Old 07-20-2005, 06:28 AM
when the ac comes on you should beable to tune the raf table to fix it, just look at the idle air trims and adjust like you would regualr idle, i am assuming this though because i have no ac so i havent done it
