Got Wideband Readings with Dyno yesturday
I dynoed my car on a Mustang Dyno yesturday...mods are in sig. They said I was runnin a bit rich at WOT. I had a friend get it a little more streetable after the cam install using EFI Live I believe. I was wondering what you guys think about these numbers.
Also, is there any advice I can give to him on what needs to be changed to get these numbers where they are suppose to be? He's fairly familiar with the program he uses, but still workin on it.
1st Pull - 365.0 HP @ 6250 PRM and 344.2 TQ @ 3250 RPM
2nd Pull - 368.3 HP @ 6250 RPM and 340.7 TQ @ 5000 RPM
The first run TQ must have been an error because thats not what the graph shows.
RPM - AFR - HP - TQ
3099 - 13.042 - 199 - 337
3319 - 12.937 - 212 - 335
3563 - 12.800 - 223 - 329
3757 - 12.629 - 237 - 331
4006 - 12.465 - 252 - 330
4389 - 12.426 - 274 - 328
4622 - 12.250 - 289 - 328
4983 - 12.229 - 319 - 336
5644 - 12.139 - 354 - 329
5956 - 12.020 - 362 - 319
6274 - 11.974 - 366 - 306
So what do you think of these numbers?
RPM - AFR - HP - TQ
