LM-1 works with PLX pid? EFIlive
Wy does the LM-1 WB work with the PLX pid and not the LM-1 pid. I had both pids up and the PLX was right on the money with the LM-1 display but the LM-1 pid was way off. Anyone no why this is? Can we just rename the PLX pid as the LM-1 for future customers? It is kind of confusing at first.
did you change the outputs on your LM1 to differ from factory calibration. If you did then that is why you are seeing the difference. What is the default voltage output and what is yours currently set at
I did not change anything at first and the afr was way off. Then i tried changing the 0 vots to 10.1 and the 5 volts to 20.1 and still it was off. Next i swithced to the PLX pid and it was right on the money. Hope this helps.
Yes sir. The grounds are hooked up and i believe everything is working perfectly. EFILive is a great tuning tool as well as the LM-1. I was just trying to figure out why the pre config pids for the LM-1 did not work correctly. I will try and download the most current version again and see if that fixes it.
