is my FAST 90 TB the problem?
7 Second Club
my car has had a few tuners and making it idle is a bitch ..... it surges alot when idling and when rolling to a slow stop.... and thats pretty much the only problem.... would the nick williams TB help solve this?
has any one else had this problem?
thanks,
Tyler
thanks,
Tyler
8 SEC SLOPPY SHOT!!!
How did they set up the throttle body drill mod or opening the blade and reseting the tps.I have a fast throttle body and the problem i had was the tps senser was not going back to 0% after moving the throttle blade a couple times.It would ether not go 100% or not zero out at idle.This made it a real bitch to get to idle.What i did was took off the tps sensor and put a small piece of foam to put slight pressue on tps and ever since that i never had idle issues.
