HP Tuners Wide Band Question
Restricted User
I have HP Tuners and I also have the Enhanced I/O. I finished installing my LC-1 and it seems to be functioning properly. The light blinks and then goes steady and the sensor gets hot. Now I try and set HP Tuners so that I can log th ewide band but I am clueless on how to get it to work. I see the options under the histogram and Narrow Band accurate is enabled. The wide band and the AFR % are grayed out and I cannot click on them. What am I missing here??? I cannot find any setting for it anywhere else...
Restricted User
Never mind, I found it. I was clicking in the table too far up and wasn't getting the auxillary menu. I am able to click on Wide Band now but what abou the AFR error %? DO I need to log first to use it?
Restricted User
Originally Posted by badass 2002 z28
I just made a thread about this...how's ur LC1 wired up? I can't get mine to work
Red ---- 12v source
Blue ---- Chassis Ground
Black ---- Switch/Led the other side of the switch and LED to chasis ground
Brown ---- HP Tuners EIO white wire
Green and White ---- HP Tuners Black wire
PM me if you have any questions...
