Switched from M6 to A4, how do I fix the speedo?
I assume you havent changed the VSS Pulses/Rev. A4 is normally around 12.68 something, M6 is 40. You want to change that.
Also the VSS Output Pulses/Mile (if yours is not greyed out) should be 4000.
Then just make sure your tire height and gear ratio is set and it will auto calculate the VSS Pulses/Mile and Trans Revs/Mile
Dixit
Dixit
Not for Vettes. But your right, for Camero Firebirds the VSS Pulses/Rev is 17 on M6 trannys and 40 on A4s.
But then again his SN does show Formula in the name, so I guess I shouldve caught that first.
Dixit
Dixit
