PO102 Diagnostic code, p/s help!
Old 08-17-2005, 10:16 PM
dplanet21's Avatar
Default PO102 Diagnostic code, p/s help!
I have a PO102 Code, which read PO102-Mass Air Flow (MAF) Sensor circuit low input. I changed the Mass air meter with a stock replacement and cleared the code, but the code reappeared. Can anyone help? Thanks.
Old 08-17-2005, 10:32 PM
WhiteRhino's Avatar
You might want to post in the pcm section or search for p102.I was getting the code as well.Mine was from 1 burnt o2 sensor wire.So It could be something that has to do with your o2's.
I dont remember what all can cause the codes,but I know o2's are one thing that can!
Old 08-17-2005, 10:37 PM
dplanet21's Avatar
Im new herer, but I found the archives. Thanks.
Old 08-17-2005, 11:18 PM
FiveSevenEagle's Avatar
check the plug ,
