Help with scanning 02 WS6
Old 08-19-2005, 02:24 PM
narc's Avatar
Default Help with scanning 02 WS6
ok guys back when i had my 94Z28 LT1 i had a OBD1 ALDL cable that i hooked to my labtop to run logs on my car and check codes via freescan..now that i have an LS1, what do i need top buy? an OBDII ALDL cable? which kind? also is there any type of "freescan" type material out there for free or cheap that i can check codes, run logs, check 02's etc via my labtop...? thanks
Old 08-19-2005, 02:26 PM
TAQuickness's Avatar
EFILive, HPT, Autotap....
OBD1 and OBD2 are two different animals
Old 08-19-2005, 02:49 PM
narc's Avatar
thanks..so which program is best/easiest to use and understand of the three and what is its website? also do i just need a OBDII ALDL cable? what pin?
Old 08-19-2005, 03:14 PM
horist's Avatar
The above require you to purchase their hardware and they provide you with software that runs on it
Autotap -- Scanner only ... I know ThunderRacing and Speed Inc sell them
HP Tuners -- PCM Tuning and Scanner in 1 package www.hptuners.com
EFI Live -- Offers just scanner or Scanner and PCM Tuning in 1 package www.efilive.com
Between those, HP Tuners and EFI Live are the best... Autotap is the cheapest however.
There's also proscan, (sponsor on right, forget web page offhand) ... they offer the cheapest scanner only, however I don't believe it supports GM Enhanced Parameters (example, Knock Retard)
B&B Electronics sells just an OBDII cable/conversion box that converts to serial data, for those that want to write their own scanning software
You'll need:
1. Cable to go from Data Link Connector to the VPW (I believe that's the GM standard?) to Serial Adapter
2. a VPW to Serial converter
3. Cable to go from Converter to Laptop
4. Software to determine what to scan on the bus
Not really any good do it yourself ones that I'm aware of...
