2005 GTO PCM Swap warning:
GM screwed up SOME of the GTO PCM's. If you try to swap your 05 GTO PCM, and it won't take, read the following:
ECM/PIM Incorrect Security Codes - keywords code linking PCM program replacement #PIC3656 - (Aug 18, 2005)
ECM / PIM Incorrect Security Codes
2005 Pontiac GTO
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Information for ECM / PIM Incorrect Security Codes
Recommendation/Instructions:
From Start of Production Model Year 05 we have an additional 4 digit immobilizer code requirement, which must be applied to reset a ECM or PIM when either one is replaced. Plant DVT randomly generates the immobilizer code from start of production was ignoring the first numeral in the code if this was a zero, in fact if the first two or three numbers were zero, it would ignore all leading zeros, and assign a three or two or one digit code. Tech 2 searches for a 4 digit code, and when it doesn't find it, reports it as an invalid immobilizer code. This has been corrected as of the breakpoint given below, when programming was changed so that random number generation commences from 1,000. Vehicles with this concern have been identified by being all with leading zeros, and have been listed by VIN.
Field Recommendation:
This will not have any impact on the operation of the vehicle unless either the ECM or PIM need to be replaced, in which case the immobilizer code necessary to achieve a reset will be unachievable. If either a ECM or PIM need to be replaced in these vehicles it will be necessary to replace both at the same time and use the existing immobilizer code. When entering the immobilizer code with the Tech 2 the zeros are recognized.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
2005 Pontiac GTO
Condition/Concern:
Note: This PI ONLY applies to the following vehicles:
6G2VX12U85L406712 6G2VX12U95L406671 6G2VX12U05L406669 6G2VX12U15L406616 6G2VX12U85L406581 6G2VX12U55L406571 6G2VX12U25L406558 6G2VX12U95L406525 6G2VX12U85L405995 6G2VX12U25L405989 6G2VX12U95L405973 6G2VX12U95L405956 6G2VX12U15L405949 6G2VX12U05L405943 6G2VX12U65L405929 6G2VX12UX5L405884 6G2VX12U45L405881 6G2VX12U35L405869 6G2VX12UX5L405867 6G2VX12U25L405846 6G2VX12U05L405831 6G2VX12U55L405825 6G2VX12U85L405818 6G2VX12U05L405800 6G2VX12U05L405781 6G2VX12U55L405775 6G2VX12U75L405664 6G2VX12U95L405651 6G2VX12U75L405633 6G2VX12U65L405574 6G2VX12U25L405541 6G2VX12U85L405527 6G2VX12U95L405519 6G2VX12U35L405516 6G2VX12UX5L405500 6G2VX12U75L405499 6G2VX12U05L405473 6G2VX12U35L405466 6G2VX12UX5L405447 6G2VX12U85L405446 6G2VX12U45L405430 6G2VX12U05L405425 6G2VX12U55L405419 6G2VX12U55L405405 6G2VX12U35L405404 6G2VX12U45L405251 6G2VX12U35L405239 6G2VX12U75L405213 6G2VX12U15L405157 6G2VX12U65L404490 6G2VX12U65L404487 6G2VX12U55L404481 6G2VX12U55L404464 6G2VX12U95L404452 6G2VX12U75L404434 6G2VX12U35L404432 6G2VX12U35L404401 6G2VX12U25L403711 6G2VX12U35L403698 6G2VX12U95L403673 6G2VX12U55L403654 6G2VX12U15L403621 6G2VX12U05L402881 6G2VX12U35L402874 6G2VX12U15L402808 6G2VX12U25L402106 6G2VX12U15L402081 6G2VX12U35L402034 6G2VX12U05L402024 6G2VX12U95L401244 6G2VX12U45L400552 6G2VX12UX5L400524 6G2VX12U75L400514 6G2VX12U25L400484 6G2VX12UX5L400457 6G2VX12U95L400451 6G2VX12U85L399809 6G2VX12U95L399785 6G2VX12U05L399772 6G2VX12U15L399764 6G2VX12U45L399709 6G2VX12U75L399056 6G2VX12U65L399050 6G2VX12U35L399040 6G2VX12U35L399037 6G2VX12UX5L399035 6G2VX12U55L399010 6G2VX12U55L398939 6G2VX12U05L398315 6G2VX12U65L398285 6G2VX12U35L398275 6G2VX12U55L398262 6G2VX12U25L398221 6G2VX12U95L398216 6G2VX12U35L398194 6G2VX12U85L398191 6G2VX12UX5L397575 6G2VX12U25L397571 6G2VX12UX5L397561 6G2VX12U75L397517 6G2VX12U15L397500 6G2VX12U75L397467 6G2VX12U45L396812 6G2VX12U25L396811 6G2VX12U55L396799 6G2VX12U85L396781 6G2VX12UX5L396720 6G2VX12U15L396718 6G2VX12U85L396716 6G2VX12U85L396697 6G2VX12U65L396052 6G2VX12U85L396036 6G2VX12U35L396025 6G2VX12U85L396022 6G2VX12U45L396020 6G2VX12UX5L396006 6G2VX12U15L395990 6G2VX12U75L395976 6G2VX12U05L395964 6G2VX12U25L395934 6G2VX12U95L395297 6G2VX12U55L395295
6G2VX12U85L395209 6G2VX12U95L395185 6G2VX12U85L394528 6G2VX12U85L394481 6G2VX12U75L394472 6G2VX12U05L394457 6G2VX12U95L394442 6G2VX12U75L394438 6G2VX12U75L393807 6G2VX12UX5L393798 6G2VX12U45L393750 6G2VX12U55L393739 6G2VX12UX5L393719 6G2VX12U85L393699 6G2VX12U15L393687 6G2VX12U45L393098 6G2VX12U95L393081 6G2VX12U95L393047 6G2VX12U55L393031 6G2VX12U45L393019 6G2VX12U95L392447 6G2VX12U15L392412 6G2VX12U45L392405 6G2VX12U55L392395 6G2VX12U65L392373 6G2VX12U55L391781 6G2VX12U75L391779 6G2VX12U25L391768 6G2VX12U85L391726 6G2VX12U25L391706 6G2VX12U95L390651 6G2VX12U45L390587 6G2VX12U75L388350 6G2VX12U15L388327 6G2VX12U05L388304 6G2VX12U95L388303 6G2VX12U75L388252 6G2VX12U45L388239 6G2VX12U65L388212 6G2VX12U95L388205 6G2VX12U15L388182 6G2VX12U05L388142 6G2VX12U95L388141 6G2VX12UX5L388133 6G2VX12U85L388129 6G2VX12U15L388120 6G2VX12U35L388099 6G2VX12UX5L388097 6G2VX12U25L388093 6G2VX12U45L388077 6G2VX12U65L388064 6G2VX12U25L387249 6G2VX12U25L387235 6G2VX12U85L387207 6G2VX12U55L387200 6G2VX12U35L387194 6G2VX12U75L387134 6G2VX12U95L387121 6G2VX12U25L386571 6G2VX12UX5L386561 6G2VX12U85L386560 6G2VX12UX5L386558 6G2VX12U05L386553 6G2VX12U65L386542 6G2VX12U45L386541 6G2VX12U95L386535 6G2VX12U65L386525 6G2VX12U15L386500 6G2VX12U55L386497 6G2VX12U55L386158 6G2VX12U95L386132 6G2VX12U15L386125 6G2VX12U25L386103 6G2VX12U75L386095 6G2VX12U35L385638 6G2VX12U95L385627 6G2VX12U25L385615 6G2VX12U65L385598 6G2VX12U25L385596 6G2VX12U25L385582 6G2VX12U95L385580 6G2VX12U75L385559 6G2VX12U15L385556 6G2VX12UX5L385555 6G2VX12U65L385553 6G2VX12U75L385545 6G2VX12U35L385543 6G2VX12U65L384743 6G2VX12U35L384716 6G2VX12UX5L384714 6G2VX12U85L384694 6G2VX12U15L384682 6G2VX12U05L384558 6G2VX12U85L384551 6G2VX12U75L384542 6G2VX12U85L384534 6G2VX12U05L384527 6G2VX12UX5L383692 6G2VX12U85L383674 6G2VX12U35L383615 6G2VX12UX5L383613 6G2VX12U85L383609 6G2VX12U95L383585 6G2VX12U15L382852 6G2VX12U65L382846 6G2VX12U25L382813 6G2VX12U05L382812 6G2VX12U25L382794 6G2VX12U95L382758 6G2VX12U85L382749 6G2VX12U25L382746 6G2VX12U35L382058 6G2VX12UX5L382011 6G2VX12U75L381981 6G2VX12U65L381969 6G2VX12U55L381283 6G2VX12U75L381270 6G2VX12U55L381266 6G2VX12U25L381256 6G2VX12U05L381241 6G2VX12U95L381206 6G2VX12U45L381193
6G2VX12U25L381158 6G2VX12U35L380441 6G2VX12U05L378095 6G2VX12U45L378083 6G2VX12U95L378046 6G2VX12UX5L378041 6G2VX12U05L378016 6G2VX12U95L378015 6G2VX12U15L377215 6G2VX12U55L377203 6G2VX12U15L377201 6G2VX12U15L377196 6G2VX12U95L377186 6G2VX12U35L377183 6G2VX12U75L377123 6G2VX12U65L377114 6G2VX12U55L377105 6G2VX12U45L376365 6G2VX12U65L376352 6G2VX12U55L376343 6G2VX12UX5L376340 6G2VX12UX5L376337 6G2VX12U85L376336 6G2VX12U75L376330 6G2VX12U35L376325 6G2VX12U65L376321 6G2VX12U65L376299 6G2VX12UX5L376287 6G2VX12U65L376285 6G2VX12U15L376257 6G2VX12U95L376247 6G2VX12U65L376240 6G2VX12U45L375443 6G2VX12U35L375434 6G2VX12UX5L375429 6G2VX12U45L375426 6G2VX12U25L375425 6G2VX12UX5L375415 6G2VX12U05L375388 6G2VX12U65L375377 6G2VX12U95L375373 6G2VX12U05L374614 6G2VX12U35L374607 6G2VX12U65L374603 6G2VX12U05L374600 6G2VX12U05L374595 6G2VX12U65L374584 6G2VX12U85L374537 6G2VX12U75L374528 6G2VX12U55L374527 6G2VX12U55L373927 6G2VX12U85L373923 6G2VX12U45L373921 6G2VX12U05L373916 6G2VX12U85L373758 6G2VX12U55L373751 6G2VX12U95L372957 6G2VX12U65L372950 6G2VX12U55L372941 6G2VX12U65L372933 6G2VX12U75L372911 6G2VX12U45L372896 6G2VX12U65L372883 6G2VX12U45L372140 6G2VX12U25L372136 6G2VX12U55L372129 6G2VX12U15L372127 6G2VX12U15L372113 6G2VX12UX5L372112 6G2VX12U85L372111 6G2VX12U35L372095 6G2VX12U25L372086 6G2VX12U05L372085 6G2VX12U35L372081 6G2VX12U95L372070 6G2VX12U25L372069 6G2VX12U55L372065 6G2VX12U25L372055 6G2VX12U75L372052 6G2VX12U65L371328 6G2VX12U25L371312 6G2VX12U85L371296 6G2VX12U75L371290 6G2VX12U95L371288 6G2VX12U35L371285 6G2VX12U95L371274 6G2VX12U35L371268 6G2VX12U95L371243 6G2VX12UX5L370506 6G2VX12U15L370491 6G2VX12U75L370480 6G2VX12U55L370476 6G2VX12U05L370465 6G2VX12U95L369718 6G2VX12U55L369716 6G2VX12U65L369708 6G2VX12U45L369691 6G2VX12U35L369679 6G2VX12U15L369664 6G2VX12U65L369661 6G2VX12U85L369659 6G2VX12U35L368905 6G2VX12U15L368904 6G2VX12UX5L368898 6G2VX12U35L368872 6G2VX12U15L368871 6G2VX12U25L368863 6G2VX12U95L368858 6G2VX12UX5L368853 6G2VX12U45L368122 6G2VX12U25L368118 6G2VX12U85L368107 6G2VX12U65L368087 6G2VX12U85L368060 6G2VX12U45L368038 6G2VX12U35L368032 6G2VX12U35L368029 6G2VX12U05L368022 6G2VX12U05L368019 6G2VX12U35L368015 6G2VX12U65L368008 6G2VX12U25L368006
6G2VX12U55L367996 6G2VX12U55L367982 6G2VX12U05L367971 6G2VX12U55L367965 6G2VX12U05L367940 6G2VX12U25L367275 6G2VX12U75L367272 6G2VX12U35L367267 6G2VX12U45L367262 6G2VX12U05L367260 6G2VX12U75L367255 6G2VX12U35L367253 6G2VX12U05L367226 6G2VX12U55L367206 6G2VX12U15L367199 6G2VX12UX5L367198 6G2VX12U95L367192 6G2VX12U95L367189 6G2VX12U55L365956 6G2VX12U85L365952 6G2VX12U65L365951 6G2VX12U85L365949 6G2VX12U15L365937 6G2VX12UX5L365936 6G2VX12U45L365933 6G2VX12U05L365931 6G2VX12U55L365925 6G2VX12U85L365921 6G2VX12U45L365916 6G2VX12U35L365888 6G2VX12U05L365878 6G2VX12U25L365865 6G2VX12U85L365840 6G2VX12U65L365822 6G2VX12U25L365820 6G2VX12U25L365817 6G2VX12U95L365815 6G2VX12UX5L365788 6G2VX12U65L365786 6G2VX12U25L363582 6G2VX12U95L363577 6G2VX12U75L363562 6G2VX12U35L363543 6G2VX12U15L363525 6G2VX12U15L363508 6G2VX12U75L363478 6G2VX12U05L363466 6G2VX12U15L363458 6G2VX12U65L363455 6G2VX12U15L363444 6G2VX12UX5L363443 6G2VX12U35L363431 6G2VX12U15L363430 6G2VX12U75L359186 6G2VX12U95L359173 6G2VX12U15L359152 6G2VX12U55L359137 6G2VX12UX5L359134 6G2VX12U65L359132 6G2VX12U55L359106 6G2VX12U45L358464 6G2VX12U85L358452 6G2VX12U55L358442 6G2VX12U15L358440 6G2VX12U15L358423 6G2VX12U65L358398 6G2VX12U75L358393 6G2VX12U55L358392 6G2VX12U45L358383 6G2VX12U25L358379 6G2VX12U05L358378 6G2VX12U65L358370 6G2VX12U25L358348 6G2VX12U55L358344 6G2VX12U65L358319 6G2VX12U05L358316 6G2VX12U05L358302 6G2VX12U55L358280 6G2VX12U75L358278 6G2VX12U95L358265 6G2VX12U95L358251 6G2VX12U35L358245 6G2VX12U95L357746 6G2VX12U25L357717 6G2VX12U95L357701 6G2VX12U55L357694 6G2VX12U85L357690 6G2VX12U85L357687 6G2VX12U75L357650 6G2VX12U15L357644 6G2VX12U35L357631 6G2VX12U25L357622 6G2VX12U95L357620 6G2VX12U05L357618 6G2VX12U85L356796 6G2VX12U05L356792 6G2VX12U75L356756 6G2VX12U75L356725 6G2VX12U35L356723 6G2VX12U25L356695 6G2VX12U25L356650 6G2VX12UX5L356637 6G2VX12UX5L356623 6G2VX12U75L355803 6G2VX12U95L355799 6G2VX12UX5L355794 6G2VX12U65L355792 6G2VX12U55L355783 6G2VX12U45L355774 6G2VX12U95L355768 6G2VX12U35L355765 6G2VX12U05L355755 6G2VX12U85L355745 6G2VX12UX5L355729 6G2VX12U05L355710 6G2VX12U25L355708 6G2VX12U05L355707 6G2VX12UX5L355701 6G2VX12U05L355691 6G2VX12U15L355683 6G2VX12U75L355672 6G2VX12U75L355669
6G2VX12U35L355653 6g2vx12u65l355646 6G2VX12UX5L355598 6g2vx12u05l355593 6G2VX12U55L355590 6g2vx12ux5l355567 6G2VX12U55L355556 6g2vx12u45l355547 6G2VX12U95L355544 6g2vx12u75l355543 6G2VX12U35L355524 6g2vx12u95l355513 6G2VX12U65L355470 6g2vx12u15l355439 6G2VX12U65L355436 6g2vx12u05l355433 6G2VX12U95L355429 6g2vx12u45l354754 6G2VX12U55L354732 6g2vx12u55l354715 6G2VX12UX5L354709 6g2vx12u15l354677 6G2VX12U75L354649 6g2vx12u05l354637 6G2VX12U25L354607 6g2vx12u15l354601 6G2VX12U35L354597 6g2vx12u15l354579 6G2VX12U45L354558 6g2vx12u15l354548 6G2VX12U35L354521 6g2vx12u35l354485 6G2VX12U75L354473 6g2vx12u55l354472 6G2VX12U55L354469 6g2vx12u65l354464 6G2VX12U95L354443 6g2vx12u35l354440 6G2VX12U95L353759 6g2vx12u55l353757 6G2VX12U95L353745 6g2vx12u35l353742 6G2VX12U45L353720 6g2vx12u85l353719 6G2VX12U45L353717 6g2vx12u95l353650 6G2VX12U95L353647 6g2vx12u15l353643 6G2VX12U55L353631 6g2vx12u35l353613 6G2VX12U05L353598 6g2vx12ux5l353589 6G2VX12U05L353567 6g2vx12u95l353552 6G2VX12U75L353551 6g2vx12u25l353540 6G2VX12U15L353528 6g2vx12u85l352215 6G2VX12UX5L352202 6g2vx12u25l352193 6G2VX12U15L352184 6g2vx12u65l352178 6G2VX12U85L352165 6g2vx12u75l352156 6G2VX12U85L352134 6g2vx12u75l352125 6G2VX12U15L352119 6g2vx12u35l349111 6G2VX12U75L349080 6g2vx12u35l349061 6G2VX12U95L349050 6g2vx12u65l349037 6G2VX12U25L348970 6g2vx12u55l348963 6G2VX12U75L348916 6g2vx12u15l348913 6G2VX12U65L348910 6g2vx12u05l348899 6G2VX12U35L348895 6g2vx12u35l348797 6G2VX12U85L348780 6g2vx12u25l348774 6G2VX12U95L348772 6g2vx12u95l348769 6G2VX12U75L348768 6g2vx12u45l348744 6G2VX12U05L348739 6g2vx12u15l348734 6G2VX12UX5L348733 6g2vx12u25l348712 6G2VX12U05L348711 6g2vx12u95l348710 6G2VX12U75L348687 6g2vx12u25l348676 6G2VX12U15L348670 6g2vx12u25l348662 6G2VX12U65L348650 6g2vx12u55l348638 6G2VX12U25L348631 6g2vx12u05l348627 6G2VX12U55L348624 6g2vx12u55l348607 6G2VX12U65L348602 6g2vx12u45l348601 6G2VX12U25L348600 6g2vx12u15l348586 6G2VX12U65L348583 6g2vx12u25l348581 6G2VX12U25L348578 6g2vx12u05l348577 6G2VX12U75L348575 6g2vx12u35l348573 6G2VX12U55L345383 6g2vx12u25l345342 6G2VX12U85L345281 6g2vx12u35l345186 6G2VX12U75L332652 6g2vx12u55l332648 6G2VX12U75L332621 6g2vx12ux5l332600 6G2VX12U25L332574
Security PIN code location 04-06
06-08-47-003 is the GM global connect service message, not sure if alldata or shopkey have this information. The PIN is located right on the BCM under the passenger side IP near the HVAC blower housing. Its on a smaller label. hope this helps. This is for 04-06
