used pcm
Old 08-25-2005, 03:19 PM
sleeperZ2000's Avatar
Default used pcm
what would it take if say i got the pcm out of a wreck ls1 for my car
Old 08-25-2005, 05:25 PM
felton316's Avatar
What do you want to do to this PCM? It looks as if you are asking a question with out the question part. Are you asking what it would take to get it to run in your car? If so, you just need it flashed with the operating system for your car, unless by some chance the wrecked car is the same year and tranny type.
Old 08-26-2005, 08:32 AM
crainholio's Avatar
About 5 minutes.
Old 08-26-2005, 09:08 AM
98z28chevy's Avatar
Theres 2 10mm bolts and a screw that hold the bracket that the pcm goes in. Also just need a 7mm rachet to take off the 2 main connectors to the pcm i took mines out yesterday. the Screw that holds the bracket is inside the wheel well if u want to take the bracket off.
