please help p0102 code is thrown thoroughly researched and worked on.
here is a link to my thread but i realized it was in the wrong forum most likely.
https://ls1tech.com/forums/pcm-diagnostics-tuning/373191-couple-engine-codes-p102-p140-p160-searched-already-stumped.html
Thanks
Louie
Thanks
Louie
no it is maf sensor low voltage. however it appears that it is run on the same circuit as the 02 sensor power wires so them melting and grounding out could cause the eng sens fuse to blow and therefore not give any power to the MAF. i know that it is not an 02 problem directly however it in many cases, not all, related.
louie
louie
