FTC goes to 20 when stopped in gear?
When coming to a stop the fuel trim cell changes to 19 when almost stopped then goes to cell 20. When it hits cell 20 the stft and ltft all zero out and don't move. It stays like this until an off idle condition is present or move shifter into neutral or park. After moving shifter into park or neutral the fuel trims will start moving after about 2-3 seconds. Other then this the car runs great. mods are below.
427ci
AFR 225
FAST 90mm intake
Mark williams throttle body
cam 256-264 649/649 113+4
42lb bosch injectors
4L60E
427ci
AFR 225
FAST 90mm intake
4L60E
Plot thickens.
I have figured out that it goes into open loop when shifted from park/neutral to D4 D3 or D1. Reverse or D2 it stays in closed loop. Does anybody know of any way the loop status can be linked to the gear selector?
