Innovate LC-1/XD-1
Innovate LC-1/XD-1
For those of you considering the Innovate LC-1, it is a great product. Finished installing the LC-1 with the XD-1 Gauge. It was real simple to install and the directions are very clear. Still waiting on my HP Tuners cable to be modified with EIO and I can still monitor my AFR with the gauge. I have been using the stock O2's to tweak WOT and I am actually running 11.9-12.0, according to the LC-1. Just a little rich and that was with the stock O2's reading ~915mV. The cable does not have connectors on the 7 wires. I ended up crimping some pins and connectors, on the wires, from Digi-Key for a OEM Look. The XD-1 guage is 52mm and installed it right beside the convert top up/down switch. It was perfect fit using a 2" hole bit from The Home Depot. I purchased the kit from Tim@EADPerformance and was $360, the cheapest I have seen yet including the XD-1.
LS1TECH Sponsor
another option is the lc-1 with dynotune digital display.
At $279 is't a killer package.
www.dynotunenitrous.com
Dan
Dan
