safe tune for FI
safe tune for FI
I just finished my car and now it is time to tune it, the ? I have is that I have read that 8-10 psi will last on the stock bottom end if it is tuned right. What are the boundries I need to stay within timing /fuel ect.
My mods are 02 Z28
p1sc-1 8-10 psi expected
comp 220/224/568/568/114 & 918 springs
42 lb injec, walbro 255 pump
LT/ORY Magna flow catback
3000 2.0str stall
3.73 rear
My mods are 02 Z28
3000 2.0str stall
3.73 rear
For starters, on the timing table, you can use your stock timing tables, just subtract 2 from 40gms up. The more boost you make and air your car consumes the less timing it will give the motor. 18 is a pretty safe number, Just make sure you allow at least 8kr allowance in the max kr vs rpm in pe. And just make sure to keep it rich, Like John says, 11:xx Is always good, Any richer and you will loose performance.
Rich does not always make it safe. You will knock with too much fuel and not enough timing. There is a balance point. You also need to ask the question of how much cylinder pressure does he have. Have you done a compression test after the cam install? This will help you understand how much the motor has to start with and how far you can take it.
Rick
Rick
