***HELP***Bad missfire at idle, random at WOT flashin SES light
I've noticed the car missing at idle and getting worse. I replaced the current NGK 55's with new ones & Taylor thunder volt wires. Missing is worse now. My first test drive the car drove amazing. I went back home and finished bolting the drivers side coil packs down and went out again. This time it ran like crap and the SES light started flashing Went back home moved the wires around on the drivers coil pack harness. Still missing at idle but fine under load...
I took it to a local shop today and they hooked a scanner up. Missfire gets alot worse at idle but still ok under load? Changed wires back to stock with no difference. Any suggestions are appreciated.
Kevin
Kevin
