Is This Much VE Change Normal?
Old 09-26-2005, 10:14 PM
Ragtop 99's Avatar
Default Is This Much VE Change Normal?
I was looking back at the total VE change needed to get my LTRIMS to around -2% and I was surprised at the magnitude of the change at low MAP. I know that 400 & 800 rpm changes would be large and that 1200 would need some change, but check out this is sample:
MAP 20
1600 rpm = -45%
2000 rpm = -38%
MAP 30
1200 rpm = -40%
1600 rpm = -30%
2000 rpm = -30%
MAP 40
1200 rpm = -31%
1600 rpm = -17%
2000 rpm = -12%
Interestingly, at high MAP (70+) I actually add a couple percent in this rpm range.
Now my set-up was designed around my previous high stall A4 configuration with my power biased for high rpm:
Cam is on an ICL of 114. Other specs: 228/224 113 XE-R lobes
Headers are 1 7/8" feeding into 3.5" piping
FAST 90mm intake
Heads are MTI heads 5.3 heads lightly milled, but valve reliefs knock my CR back into the low to mid 10.X range.
So is reasonable for my set-up or is this a sympton of a mechanical issue or another tuning issue (e.g. idle air, timing) that is out of whack?
The car idles hot at 850 with a MAP in the high 40s and IAC count in the low 40s. High Octane table is stock M6, either 99 or 00, I forgot which.
Old 09-26-2005, 10:19 PM
HumpinSS's Avatar
Yes that is normal with the overlap and the cam at idle it isnt to efficient as an airpump. This causes you to have to drastically cut ve values in order to get the correct LTRIMS and AFR. I would still want to verify your changes with a WB.
Code:
34.039302	34.498223	35.115393	35.518927	35.811687	35.930374	35.693001	35.550577	35.392328	35.257817
37.781884	36.144010	36.341821	36.610843	36.871954	37.354612	37.283401	37.077677	37.402087	36.721618
41.738102	40.100228	40.448375	40.875647	41.279181	43.178166	40.503762	39.562182	42.291973	43.660824
45.765532	45.393648	46.026643	46.667550	48.368724	47.577480	45.583546	47.632867	50.797842	53.796655
50.006598	50.797842	51.747334	52.649352	51.652385	53.677969	54.682848	57.618362	59.873407	61.709092
15kpa-60 400 rpm-2000 on my cam only G5X4
Old 09-26-2005, 10:23 PM
bmfcamaro's Avatar
how many times were those cells hit. if not many it could be just error.
Old 09-27-2005, 07:17 AM
YellowToy/A's Avatar
If it is not a 2001 or 2002 u need to edit the back up VE table.
Old 09-27-2005, 07:55 AM
Ragtop 99's Avatar
BMF: They get enough hits to measure. I log about 2000 data points each time. For each point, I use excell to round MAP Kpa to the nearest 5. Then for each Kpa point, I look at the data for +/- 100 rpm. So the adjustment for MAP 40 at 1600 rpm is based upon the average of all readings from MAP 37.5 @ 1500 rpm to MAP 42.4 @ 1700 rpm. I also scan the data for any outliers and ignore them.
Yellow: I edit both tables. 95% of the change was done originally with the MAF fail = 0, so that I was on the secondary table. I also copied over the high octane table to the low octane table during that time.
Humpin: I'm not sure how to read that table. LS1Edit uses different numbers in the VE table.
Old 09-27-2005, 09:10 AM
HumpinSS's Avatar
If I am not mistaken you have to multiply by 30 or 29.96
