Which side is the negative side on the injector connectors??
Old 10-02-2005, 05:14 PM
frcefed98's Avatar
Default Which side is the negative side on the injector connectors??
Hooking up a meth injector kit, the control box needs to tap into the ground side of the injector connector..
which side is the negative side on the connector? It doesn't matter which injector..
J
Old 10-02-2005, 06:10 PM
frcefed98's Avatar
TTT some has to know this...
Old 10-02-2005, 06:44 PM
kbracing96's Avatar
unplug the connector from the injector and put a meter on each terminal on the connector. the one that is not hot is the ground.
