Startup Friction Airflow Correction table?
Moderator
Below is on a 98Z28 A4 using EFILive
Today I played with this table in an effort to correct a warm starting problem and it seemed to work okay. But…
The problem is that when you transition from park to drive or drive to park it seems that the values in {B4343} Startup Friction Airflow Correction table are also added to the {B4703} Desired Airflow table and the IAC counts jump up and as expected the idle increases.
I thought that the values in {B4343} were only applied at startup and for a very short time afterwards as controlled in the {B4344} Startup Friction Airflow Decay and {B4345} Startup Friction Airflow Delay tables.
Does anyone have any experience with the idle start-up tables?
Thanks
John
Thanks
John
Moderator
If I set the running airflow (desired airflow) table to a value that is high enough for car to start and run it ends up being too high and when I go to park/neutral from gear the engine races.
John
John
