need help... replacing optispark distributor
anyone have any tips on how to replace the optispark distributor? sure would be appreciated..
95 lt1
.30 over
msd, ignition
flow master super 40
17 inch koenig monsoon rims (245 -45-70)goodyear eagle gt
ceramic brakes
95 lt1
.30 over
msd, ignition
ceramic brakes
I think this question would be better suited in the LT1 section, but here goes. You will have to remove your throttle body, waterpump, radiator, fans, and I always pull the power seering pulley off. You will have a straight shot at the opti. I always take a paint marker and mark all plug wires so there is no confusion on re-install. There is three 10mm bolts that hold the opti in place, you can't install wrong because of the cams dowel pin. Then re-install everything and fire the car up.
