help with oil change light
Old 11-09-2005, 07:28 PM
project nightmare's Avatar
Default help with oil change light
my oil change light comes on when i start the car and stays on for about a mile and then goes off. i don't have any clue to why this would happen all of a sudden. the car only has 40k . 2000 trans am. m6 ws6
Old 11-09-2005, 07:32 PM
chaman's Avatar
Look into your manual. It needs to be reseted. Throw a search about oil light reset.
Old 11-09-2005, 07:48 PM
Pavetim's Avatar
Default Oil light
On my 2002 you hold in the odometer rest for 12 seconds. I forget if the oil change or service engine light flashes. But it will flash a few times and then the oil change will be reset.
Old 11-09-2005, 08:09 PM
2001NBMZ28's Avatar
Turn the key to run, don't start the car - Press and hold the trip/oil reset button until it flashes and goes off...if you don't want to reset the trip miles turn the key to run, depress the gas pedal 3 or 4 times.
Old 11-09-2005, 09:52 PM
rtr2001ss's Avatar
I've tried that method, but didn't get the "Change Engine Oil" light to flash, showing reset. The Trip/Oil one does work.
Old 11-11-2005, 07:13 AM
gwj
gwj's Avatar
Location: Live Oak, FL - in the woods where the creatures lurk.
The light won't flash when you use the pedal, at least on a 2000. It just will go off. Also you need to turn the key on and pump the pedal 3 times immediately while it's still "booting up". Has always worked for me.
Old 11-11-2005, 07:55 AM
Bill Bowling's Avatar
Talking
This works for me also.
Bill
