PIDS for boost??
Old 12-19-2005, 08:46 PM
ninobrn99's Avatar
Question PIDS for boost??
is there any way to log your boost with tuners or efi?
Old 12-19-2005, 09:20 PM
horist's Avatar
MAP is about the best you can get ... 100KPA = 0 boost, 0 vacuum, 200KPA = 14.5 or so PSI Boost, etc....
I'm assuming it's a linear flow (so 150kpa is about 7 or so PSI of boost)
Old 12-19-2005, 09:24 PM
ninobrn99's Avatar
thanks
Old 12-20-2005, 12:19 PM
kbracing96's Avatar
6.9 KPA = 1 lbs of boost
Old 12-20-2005, 12:21 PM
HumpinSS's Avatar
also to make life easier you will need a 2 bar map sensor and a 2 bar os available from both EFILive and HPT. there are other ways but you will be doing a lot of lying to the pcm
