want to change rev limiter
Old 12-25-2005, 08:27 PM
ls1chris's Avatar
Default want to change rev limiter
ok i just got a hypertech programer and goin to change my rev limiter my mods are in sig. i was thinking bout goin to 6000 what do you all think will be a safe limit to go? just thinkin of getting that lil extra mmf in theirl lol i know this is not the greatest programer out their but any info i can do with it is appreciated . My car is 98 TA six speed
Old 12-25-2005, 08:58 PM
LS1TECH Sponsor
foff667's Avatar
stock limiter is 6200 so i think you'd be safe at 6000
Old 12-25-2005, 09:04 PM
98TADRIVER's Avatar
u although the LS1 will pull all the way to the rev limiter, i wouldnt recommend going over 6200rpm. i powershift my t/a at 5500 rpm which seems to be the optimum shift point on my car. Unless u get a bigger cam/lifters/springs i wouldnt bother with it.
Old 12-26-2005, 01:20 AM
BriancWS6's Avatar
The fuel shutoff is at 6250. So leave it alone unless you get an aftermarket cam and springs. You could just get springs and the rest of the complimentary valvetrain...but there would be no reason as shifting higher would only slow you down. The stock cam flatlines around 5500. I have my shiftlite set at 6k, works great.
Old 12-26-2005, 03:32 PM
2002_Z28_Six_Speed's Avatar
I wouldn't go over 6200 unless your F-body isn't your daily driver. It isn't worth the slight gain.
Old 12-27-2005, 12:07 PM
BriancWS6's Avatar
There is no gain, you would be revving too far past peak power and would actually slow down
