Code PO327, PO430???
Old 06-27-2002, 12:44 AM
PewterZ28's Avatar
Default Code PO327, PO430???
Anyone know what these codes mean?
Derrick
Old 06-27-2002, 12:50 AM
JPJBC's Avatar
Default Re: Code PO327, PO430???
p0327 is knock sensor circuit low voltage and the p0430 is catalyst system low efficiency bank 2.
Old 06-27-2002, 01:20 AM
taqwache's Avatar
Did you cut your cats off or any other mods. This could explain you codes. if you did you could fix it with O2 simulators and a MAFT. just a thought.
Old 06-27-2002, 01:41 AM
PewterZ28's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by JPJBC:
<strong>p0327 is knock sensor circuit low voltage and the p0430 is catalyst system low efficiency bank 2.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I originally thought that I had a bad O2 sensor, but I was a bit surprised when 2 separate codes were given. Could 430 be an O2 sensor? I might try swapping out the passenger side O2 sensors with new ones from my '02 Z28. What do you think?
Derrick
Old 06-27-2002, 07:12 AM
dfarmercse's Avatar
Yes 430 is the right bank sensor 2. That is the one behind the cat. Before going to all that trouble, did you run a O2 system check? Might be worth the trouble.
Quick Reply: Code PO327, PO430???
