LS1 Sensors, interchangable with other GM's???
Old 01-14-2006, 03:56 PM
SMonty's Avatar
Default LS1 Sensors, interchangable with other GM's???
I'm wondering if I can grab sensors from any other GM's other than a camaro/firebird, that will work. I'm building an engine from scratch basically, so I'll need all the electrical to make it run. Any help would be great.
Old 01-14-2006, 04:58 PM
2002_Z28_Six_Speed's Avatar
Coolant temp sensor should be the same.
Old 01-14-2006, 06:56 PM
SMonty's Avatar
one down, thanks,
bazillion more to go guys.
what about crank and cam position sensors, air flow/temp/pressure,
help me out here.
thanks
Old 01-14-2006, 06:58 PM
Haans249's Avatar
Best way to check is to get the part numbers for them, go onto GMpartsdirect.com and look at their catalog. Search by part number, and then it'll show you all the vehicles it will be found on or used on.
Best of Luck!
Adrian
Old 01-14-2006, 11:18 PM
SMonty's Avatar
beauty, thanks for the tip.
Old 01-16-2006, 11:54 AM
jyeager's Avatar
Obviously if the part #s are the same they'll work. But sometimes changes in part #s are due to reasons other than a change in the electrical signal being output. So there are interchanges you can do in spit of part # differences.
