Going back and checking setup on wideband...(.5 difference in AFR)
I need to go over the setup of a wideband and integrating it into HP2.0. On the Innovate you can set the parameters:
0 - 4.98 volts
10 - 20 AFR
Output AFR
On the HP 2.0 select the LM1 interface, is there any properties that you can change? I am getting a .5 AFR difference between the 2.
Phil
0 - 4.98 volts
10 - 20 AFR
Output AFR
Phil
you need to tighten that up a little. HPTs cable is 0-5 volts you need to have the ranges look like
0-10 5-20 then the formula would be afr-v*2+10. you are losing a lot of resolution the way you have it set now
