Hp tuners and rear o2 sensor delete
I found a shop to tune out my rear o2's for 50 bucks for after I get the cats gutted but I still want to pass emissions. All we have here in Austin is the test where they plug your car into a handheld device and scan for codes. Can someone who knows HP tuners help me out and tell me exactly what codes need to be switched to "no report". I think you can only pick from 1, 2, or 3 and one of those doesnt store or report a code. I think I remember reading that if you just delete the codes they will still catch it at inspection time. Thanks.
-Jason
-Jason
These are the codes I found. If I have these turned to the right number I should still pass the emissions diagnostic scan?
Rear o2 codes
P0137 HO2S Circuit Low Voltage Bank 1 Sensor 2
P0138 HO2S Circuit High Voltage Bank 1 Sensor 2
P0140 HO2S Circuit Insufficiency Activity Bank 1 Sensor 2
P0141 HO2S Heater Circuit Bank 1 Sensor 2
P0157 HO2S Circuit Low Voltage Bank 2 Sensor 2
P0157 HO2S Circuit High Voltage Bank 2 Sensor 2
P0160 HO2S Circuit Insufficiency Activity Bank 2 Sensor 2
P0161 HO2S Heater Circuit Bank 2 Sensor 2
P0420 Catalyst System Efficiency below threshold Bank 1
P0430 Catalyst System Efficiency below threshold Bank 2
Rear o2 codes
