swapping 02 motor, trans, pcm harness to 98
anybody no any issues i may have with this swap? i have a 98 z28 automatic and swapping in a 02 ws6 set up with a lot less miles. i know the fuel system is different so i bought an new fuel tank and pump but i'm not sure of any other issues i may have. especially wiring/ harness problems.
The cluster won't work right either - temp gauge will expect a direct wire to a different style temp sensor for one. Oil pressure sensor is different too I believe. You might be better off just dropping the motor in there, leaving the 98 PCM and harness alone, and swapping your 1998 water temp and oil pressure sensors to the new motor.
