LS1-Edit: WOT Power Enrichment ??
What does the Max Power Enrichment number entry do for you? It is set at about 1.12 but in the PE vs RPM table there is a 1.24 multiplier across the RPM range. Does that mean the maximum power enrichment at WOT would be 1.12 times the MAF reading or 1.24 times the MAF reading? Tuning at WOT should be done using the PE vs RPM table, right? Just in need of clarification.
Paul J.
Paul J.
Re: LS1-Edit: WOT Power Enrichment ??
My understanding is as follows : There is certainly a limit to how much extra fuel you would want to add under ANY conditions.. Since there are numerous independent control tables that each CAN add fuel (i.e. COT, PE/RPM, PE/TEMP, etc), and since all of these tables are added together to determine actual total enrichment, it would be possible to get a ridiculous total enrichment.. so the max number is simply a limit to the total applied enrichment..
Paul J,,, This is an excellent question,, I have wondered about this same thing myself.
The above post did not answer your question. As you said, the max enrichment is set at 1.12 in one table,, but then in the PE vs RPM table the value is 1.24...
Now since 1.24 is bigger than 1.12,, are we getting the 1.24 or not???
I have worked on the PE vs RPM table while on a chassis dyno equipped with a good wide band O2 sensor. As far as I can determine, the 1.12 value does not effect the fuelling that I did in the PE vs RPM table. I change the value in the PE vs RPM table from 1.15 to 1.18 to 1.24 and got the proper richer or leaner AFR for the change I made.
So the 1.12 value is still a mystery to me.
