The P0101 Code
Location: Johnsonville, SC; but orginally from GAINESVILLE, FL
The P0101 Code
I recently installed heads and cam on my 2000 coupe and had things dyno tuned and the only code I throw is the P0101. I am not loosing any performance or anything, but the code just continues to pop up regularly.
Well, I took some time and clean out my MAF (which has been descreened and added high performance MAF housing) and I cleaned the sensor that runs to my air bridge and for a day it was cool, but it is back.
So, I am thinking that maybe I should just try and get a stock MAF with a screen and try that. EG told me that I should get a stock air bridge, but I spent some good money on the bridge I have, so I am really wanting to keep it.
I was also thinking that maybe I could trade my current MAF and airbridge for the stock setup and maybe a little cash.
Any ideas or recommendations?
Thanks in advance,
Micah
Thanks in advance,
Micah
Originally Posted by Assassin
or you could just tune out the p0101 error, do you have hptuners?
Thanks for the advice.
Micah
ditch the maf, put a stock one back on there. a maf that is screwed with and not properly calibrated will mess with you big time. although now its tuned so a stock one might give you issues.
a guy just had a similar issue with the code as you and it was his map sensor
